Hellspcangel911 Posted August 30, 2022 Report Share Posted August 30, 2022 Good evening all, After scouring the internet for some information I found this forum. Several weeks of reading through older posts and learning a lot I thought I could post looking for more specific information. I have a 2015 Masterspas Swimspa where one of the pumps went causing the breaker to flip and the water to freeze, the damage was one section of PVC. I’m in the process of repairing and upgrading it and hope to accomplish a reliable swim spa for my family to enjoy that runs on propane and uses salt water instead of chlorine due to a skin sensitivity shared with my wife and kids. I reached out to the manufacturer who said the spa cannot be converted to salt water but wasn’t able to give any specific reasons. I would guess it’s harder on components and would void the warranty? my ultimate goal is to run the spa through a exchanger and connect it to the wood boiler (part of an on going 40x60 barn build, the high efficiency boiler will heat the house and barn). But in the mean time I’d love to convert it to propane (which would be used in the summers as well) . One option I found is the Pentair Master temp, which is still vastly oversized for a 2,000gal tub. Another option, I see one post where someone uses a 75k btu DHW with an exchanger for their spa setup with favorable results. any help would Be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Hellspcangel911 Posted October 31, 2022 Author Report Share Posted October 31, 2022 update- I purchased a Raypak 406A propane heater, which should be able to bring the temp up pretty quickly to go from 80 degrees for swimming to 100 for spa use. I will try to use the existing Balboa ms 1700 controller and add relays/contactors to control the Raypak through its 'remote' terminal. Quote Link to comment Share on other sites More sharing options...
