In Hot Water Posted August 28, 2022 Report Share Posted August 28, 2022 Any one else seeing these things crack? Brand new tubs. Gettin tired of chasing them. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 28, 2022 Report Share Posted August 28, 2022 No never. Do you see this this happening to a single brand of spa? Are the cracking in the same spot? What brand of spa are you seeing this happen to? Quote Link to comment Share on other sites More sharing options...
In Hot Water Posted August 29, 2022 Author Report Share Posted August 29, 2022 Cal Spa, and their lower line of American Spa. It's the 2" suction wall fitting 215-3620. They are cracking in the throat of the wall fitting as if over-tightened, however I'm no so sure that's whats doing it. Wondering if they are having problems over there at Waterway, and using Re-Grind or something. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 29, 2022 Report Share Posted August 29, 2022 I think if it was a Waterway issue it would be across most MFG's and not just Cal Spa. Some spas built during the early part of the pandemic had people doing jobs that they normally didn't do so over tightening might be the issue. Quote Link to comment Share on other sites More sharing options...
In Hot Water Posted August 30, 2022 Author Report Share Posted August 30, 2022 Thank You Sir! Quote Link to comment Share on other sites More sharing options...
