Best way to replace insulation?
6010fd12
Just replaced all the jets on my 2013 jetsetter and now I want to replace the insulation that I had to rip off. I still have the old foam but most of it is in smaller pieces so it would be a little difficult to reuse. I want to avoid using spray on foam (except for the bottom of the tub that I took a chunk out of) just in case if I ever have to go in again to make a repair.
Would using fiberglass insulation be a good alternative to stuff in there? Any ideas?
  • 4 months later...
I completely forgot about this post but I guess now is as good of a time as any to reply in case someone else wants to do this. I actually ended up stuffing it with the cheapest stone rockwool insulation that I could find at menards. Specifically this one. Out of the 7 or so pads that were in the package I ended up using around 5 and a half to fill both sides of the tub. I also ripped out all the rotted out wood and glued new parts of the frame in it's place. Hope that helps someone.
  • Like 1
  • Thanks 1
