6010fd12 Posted August 12, 2022 Report Share Posted August 12, 2022 Just replaced all the jets on my 2013 jetsetter and now I want to replace the insulation that I had to rip off. I still have the old foam but most of it is in smaller pieces so it would be a little difficult to reuse. I want to avoid using spray on foam (except for the bottom of the tub that I took a chunk out of) just in case if I ever have to go in again to make a repair. Would using fiberglass insulation be a good alternative to stuff in there? Any ideas? Quote Link to comment Share on other sites More sharing options...
Cusser Posted August 12, 2022 Report Share Posted August 12, 2022 I would stuff in fiberglass insulation. Wear gloves and long sleeves, and dust mask. Quote Link to comment Share on other sites More sharing options...
ratchett Posted August 12, 2022 Report Share Posted August 12, 2022 I would use stone rockwool fiber insulation - stuff into black contractor bags and carefully place into position. Wear a respirator Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted December 18, 2022 Author Report Share Posted December 18, 2022 I completely forgot about this post but I guess now is as good of a time as any to reply in case someone else wants to do this. I actually ended up stuffing it with the cheapest stone rockwool insulation that I could find at menards. Specifically this one. Out of the 7 or so pads that were in the package I ended up using around 5 and a half to fill both sides of the tub. I also ripped out all the rotted out wood and glued new parts of the frame in it's place. Hope that helps someone. 1 1 Quote Link to comment Share on other sites More sharing options...
