Lynney Posted August 6, 2022 Report Share Posted August 6, 2022 2018 Cal Spa jets work on low, but when turned to high, it just clicks and won’t switch over to high. IMG_5327.MOV Quote Link to comment Share on other sites More sharing options...
Mike223 Posted August 6, 2022 Report Share Posted August 6, 2022 Either the pump has a bad capacitor or supply voltage is not stable enough. You can power down the entire circuit and verify there are no loose wires anywhere, including inside the subpanel at the bottom of each breaker. If it’s the cap on the pump, check your warranty period. Likely will need to be replaced. Quote Link to comment Share on other sites More sharing options...
