Schnorch Posted August 2, 2022 Report Share Posted August 2, 2022 I have a gecko in-yj-2 control system and the heater seems to be damaged. Now there is a 3 kw heat.wav that I could use. Is it compatible with my control system? Quote Link to comment Share on other sites More sharing options...
cranbiz Posted August 3, 2022 Report Share Posted August 3, 2022 Calling @CanadianSpaTech our resident Gecko expert. I suspect it will be fine but will defer to him for a definitive answer. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 3, 2022 Report Share Posted August 3, 2022 5 hours ago, cranbiz said: our resident Gecko expert. Sadly not seeing much of the newer Gecko stuff. Would likely depend on if you have the incoming electrical to support using increased KW being used https://gdeuro.com/buysystems/heatwav-yj-2-240-2-inc-if-t-4z4x5-hwc53 Quote Link to comment Share on other sites More sharing options...
Schnorch Posted August 4, 2022 Author Report Share Posted August 4, 2022 Thank you. Basically I have the following problem: The water heater indicator is lit up and the heater is active, but suddenly it flashes and the heater turns off. Sometimes it flashes after 10 minutes, sometimes after 2 hours. We got the hot tub since September 2021 and the issue in this summer. The hot tub filters 8 hours per day und the sun always shines on it. Is there a overheat protection in the system, which turns off the heater or what is the matter? I have a gecko in-yj-2 control system, a 2 kw heat.wav and easy 4 control panel Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 4, 2022 Report Share Posted August 4, 2022 1 hour ago, Schnorch said: The hot tub filters 8 hours per day Reduce that to 2 hours 2 x a day/night. If you think there is an overheat problem open a panel for a day and see if it reoccurs. If you have more than 1 pump and run a main pump for filtering and heating (no circ) once you put both pumps on high in most systems the heater will cut out. Remove the filter and run without for a day to ensure dirty filters are not slowing the flow of water going through the heater tube and causing fault. Quote Link to comment Share on other sites More sharing options...
Schnorch Posted August 10, 2022 Author Report Share Posted August 10, 2022 Thank you. It wasn´t an overheat problem. I changed the heater and it is fixed. Perhaps the temperature sensor was broken. 1 Quote Link to comment Share on other sites More sharing options...
