Ape Posted July 29, 2022 Report Share Posted July 29, 2022 Hello guys! I bought a used Balboa spa pool. Previous owner said that the fixing price would be very expensive but I wanted to take the challenge. Obviously there was something wrong because nothing happened when I powered on the system. I opened the case and motherboard was broken. The was clear mark where the folio had burned (attatched picture). I fixed the burned folio by tinning it and everything looked good, after I tinned the board I wanted to make sure everything is right, local electronics repairman checked the system and said that everything is fine on motherboard. He couldnt test board with 3-phase but tested all phases without problems. I noticed that the motherboard had problems because previous owner tried to attatch 3 phase power and didnt disconnect all the wires correct. Now I tried to attach motherboard to pool and I connected all the systems on their right places. My house burns fuse when I plug power on to the board. What should I check next? Sorry for long story but hope you can help me. Ape from Finland Quote Link to comment Share on other sites More sharing options...
Spa Shop Rotorua Posted July 31, 2022 Report Share Posted July 31, 2022 On 7/29/2022 at 6:06 PM, Ape said: Hello guys! I bought a used Balboa spa pool. Previous owner said that the fixing price would be very expensive but I wanted to take the challenge. Obviously there was something wrong because nothing happened when I powered on the system. I opened the case and motherboard was broken. The was clear mark where the folio had burned (attatched picture). I fixed the burned folio by tinning it and everything looked good, after I tinned the board I wanted to make sure everything is right, local electronics repairman checked the system and said that everything is fine on motherboard. He couldnt test board with 3-phase but tested all phases without problems. I noticed that the motherboard had problems because previous owner tried to attatch 3 phase power and didnt disconnect all the wires correct. Now I tried to attach motherboard to pool and I connected all the systems on their right places. My house burns fuse when I plug power on to the board. What should I check next? Sorry for long story but hope you can help me. Ape from Finland Hi, so to confirm you are connecting back up with 3 phase? sounds like you have a neutral and phase transposed Quote Link to comment Share on other sites More sharing options...
