Meganc Posted July 18, 2022 Report Share Posted July 18, 2022 Hello, we have a Vita spa that has developed a leak. It started small where I thought it was condensation from the cover, however over the week it’s gotten larger. We we were able to locate it and know the leak is coming from the pump union, however we can’t tighten the union at all or loosen it. Some of the videos we watched indicate their might not even be a o ring or seal of any type inside, so if that were the case why would it be leaking and what do I do to fix it? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 18, 2022 Report Share Posted July 18, 2022 Power off and close the gate valves that are just before and after the pump. Because I do this every day I use an oil filter wrench to tighten and loosen pump unions. If you don't have one you can use a flat head screwdriver and a small hammer or something that you can use to tap the back end of the screwdriver. You will see knubs that go around the female part of the union. Use the flat head screwdriver up against the knub and gently tapping to tighten or loosen the union. It likely just need a few taps to tighten it up and stop the drip. If that doesn't work back it off all the way and check/replace the o-ring. Quote Link to comment Share on other sites More sharing options...
Meganc Posted July 18, 2022 Author Report Share Posted July 18, 2022 Thank you! We tried with a wrench strap and had no luck, but it’s also at a weird angle because the leak is of course on the one side it’s tucked up against the deck. Will pick up a oil filter wrench and try that. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 18, 2022 Report Share Posted July 18, 2022 This or similar type: https://www.amazon.ca/TEKTON-5866-12-Inch-Filter-Pliers/dp/B000NPR33O?th=1 Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 18, 2022 Report Share Posted July 18, 2022 I find Irwin Vise Grip 12LC very handy, couldn't live without it (I own 2). Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 18, 2022 Report Share Posted July 18, 2022 I have a large channel lock plier that I use for doing fittings like that. Quote Link to comment Share on other sites More sharing options...
Meganc Posted July 19, 2022 Author Report Share Posted July 19, 2022 On 7/18/2022 at 7:39 AM, CanadianSpaTech said: This or similar type: https://www.amazon.ca/TEKTON-5866-12-Inch-Filter-Pliers/dp/B000NPR33O?th=1 The pliers worked, thank you! We found this is the issue. Is it just a normal o-ring or am I looking for something else? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 20, 2022 Report Share Posted July 20, 2022 https://www.youtube.com/watch?v=ML3SWLBhTsA Quote Link to comment Share on other sites More sharing options...
BigDog4All Posted August 12, 2022 Report Share Posted August 12, 2022 On 7/18/2022 at 7:32 AM, Meganc said: Thank you! We tried with a wrench strap and had no luck, but it’s also at a weird angle because the leak is of course on the one side it’s tucked up against the deck. Will pick up a oil filter wrench and try that. Congrats you were able to get the pump union loose. I too have the same problem. I have to replace a dripping Gate Valve and have tried everything. Two different wrenches as shown here. It's the weird angle and no room to grip the wrench. Also no room for the screwdriver / hammer method. I can reach all the other unions in the tub except this one, but the exit pump union, can not get a grip on the pump union. I was thinking of trying cutting, drumell tool, hack saw, but don't want to damage threads on the pump, since I will need to tighten the new ring.....but can't get angle to tighten..... Did you replace the O-ring and fix the leak? Quote Link to comment Share on other sites More sharing options...
