Cheesie Posted July 11, 2022 Report Posted July 11, 2022 Hi all, I have just purchased a hot tub and seriously having issues with understanding how to treat the water.. I have the strips that test the water, but it all seems quite high (colour gradience) so I put the minus pH in.. I then need to add more alkalinity so I do and it rockets up.. After 2 days of using the tub, water has gone murky so I've changed the filter and was told to chlorine shock it.. My point is, how often do I need to treat the water and when and how do I get crystal clear water (it's only been filled a week..!) Each time I test the water to use, it never seems right and haven't been able to use it other than the first 2 days..?! Should it be this difficult or am I just thick..?? Quote
Krulligo Posted July 11, 2022 Report Posted July 11, 2022 Test trips are garbage don't rely on them let alone be dumping chemicals in a new spa based on your interpretation of their inaccurate results. Get yourself a good pool/spa chemistry drop test kit. You will thank me later. The one I use for both my pool and spa is the Taylor K2006C kit. Works great and never had better water or any issues once I started testing with this kit. Very consistent and accurate readings. You can do both chlorine or bromine tests (for bromine, multiply chlorine test value by 2.25). Once you get a good test kit and still don't understand what chemicals to add or how much, there are people here that will help out based on your accurate readings. Quote
ratchett Posted July 11, 2022 Report Posted July 11, 2022 New tubs are filthy from factory assembly/testing - lots of nasty stuff festers in the plumbing before delivery day. Additionally, internal components are still pH neutralizing. Your water chemistry is going to be a mess for the first fill. Plan on using extra sanitizer and pH/TA balancing chemicals for the first few weeks, and then plan on a purge/drain/refill after the first 4-8 weeks. I promise water chemistry is much easier after the first refill. Quote
