Theshroders Posted July 3, 2022 Report Share Posted July 3, 2022 Recently purchased a Wellis tub and went to drain and replace the water today. The drain plug is one where you are supposed to push it in, pull it all the wat out and then attach a hose. Ours is completely stuck. Will not move at all. Anyone got any ideas at all? Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 3, 2022 Report Share Posted July 3, 2022 Post pictures. And don't be a girly man !!! Quote Link to comment Share on other sites More sharing options...
deadmeatdab Posted July 13, 2022 Report Share Posted July 13, 2022 I'm having the exact same issue with my brand new Wellis! Did you have any luck getting your drain plug to open? Quote Link to comment Share on other sites More sharing options...
JWM6687 Posted July 13, 2022 Report Share Posted July 13, 2022 I had the same issue with my Wellis (Bueno Spa) when I purchased it in March. It was impossible to open it just using with the cap they have on the end of the drain. I connected a 4" long pressure reducer I had laying around from my lawn irrigation equipment, which gave me enough leverage to pop it open. You can probably just connect a normal garden hose to give you the proper leverage to pop it loose. Here's the actual pressure reducer I used to get it open the first time. https://www.lowes.com/pd/Mister-Landscaper-Polypropylene-Hose-Thread-Drip-Irrigation-Pressure-Regulator/1103273 Quote Link to comment Share on other sites More sharing options...
deadmeatdab Posted July 14, 2022 Report Share Posted July 14, 2022 Thanks JWM6687, I'll give that a try Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 15, 2022 Report Share Posted July 15, 2022 @deadmeatdab I always tell my customers not to use the drain. Weakest part of any hot tub. Buy a Quick Drain. You can use it to drain the spa but also as a vacuum to pick up small debris in the foot well and on the seats without loosing a bunch of water. https://www.poolstorecanada.ca/products/quick-drain Quote Link to comment Share on other sites More sharing options...
Chisox10 Posted February 10, 2023 Report Share Posted February 10, 2023 On 7/3/2022 at 9:05 AM, Theshroders said: Recently purchased a Wellis tub and went to drain and replace the water today. The drain plug is one where you are supposed to push it in, pull it all the wat out and then attach a hose. Ours is completely stuck. Will not move at all. Anyone got any ideas at all? Did you ever get it opened? I have drained my tub twice now without being able to open it. I was afraid of breaking it. Quote Link to comment Share on other sites More sharing options...
Grumps Posted May 13, 2023 Report Share Posted May 13, 2023 Don't know if you have the issue resolved, but what I did was to remove the black screwcap with the tab and replaced it with a "y" valve from the garden spigot to pull it out. I'm guessing the black cap is a softer material that bends rather than a hard (plastic or metal) female device. Just need a harder grip on the male extension to pull it out to start the flow. Quote Link to comment Share on other sites More sharing options...
