6010fd12 Posted June 24 Report Share Posted June 24 2013 Jetsetter. Doing some maintenance on it by replacing tubing, ozonator, etc and noticed that there is a bunch of corrosion on the heater. Will this effect the performance any? Should I clean it off/leave it be? If I should remove it what's the best way? Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted June 25 Author Report Share Posted June 25 Bump. Any idea on what the best method to clean this stuff out is? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 25 Report Share Posted June 25 It's not corrosion, it's scale, aka hard water deposits, caused by calcium. In water, it is the result of high ph, and on surfaces the result of evaporation, which means a small leak. Acid will dissolve it, but can damage the heater element. If you have good flow through it, just watch your ph and let it go. If it's clogged, get a new one. 2 1 Quote Link to comment Share on other sites More sharing options...
Cusser Posted June 26 Report Share Posted June 26 15 hours ago, RDspaguy said: It's not corrosion, it's scale, aka hard water deposits, caused by calcium. In water, it is the result of high ph, and on surfaces the result of evaporation, which means a small leak. Acid will dissolve it, but can damage the heater element. If you have good flow through it, just watch your ph and let it go. If it's clogged, get a new one. I agree that there's been or still has a leak, and that calcium carbonate has deposited from the water. Vinegar-soaked rags would be my choice to try to remove the deposit, but the leak still may need addressing. Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted June 26 Author Report Share Posted June 26 1 hour ago, Cusser said: I agree that there's been or still has a leak, and that calcium carbonate has deposited from the water. Vinegar-soaked rags would be my choice to try to remove the deposit, but the leak still may need addressing. Is there a rebuild kit I can purchase for this heater? Edit: Found it. However the reviews mentioned that a small leak did persist after replacing them but I'm going to give it a try. https://www.amazon.com/gp/product/B07CPHF49G/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.spadepot.com/gasket-Kit-4-Watkins-Hot-Spring-Double-Barrel-Heater-P3111 Quote Link to comment Share on other sites More sharing options...
