Mikeybobo Posted June 21, 2022 Report Share Posted June 21, 2022 Hi all, I have a three rivers spa that is blinking the three lights meaning lack of water flow over the heater. It has a brand new pump and seems to operate fine other than I can’t get it to go above 95 degrees. When I turn the jets on high the three blinking lights stop and come back on when I turn the jets off. Water flow does seem to be coming out when on low speed, not sure if it’s the proper volume or not. I removed filters and ran it with the same results to eliminate clogged filter answer. Anyone have any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
