ArcticCub Posted June 19, 2022 Report Share Posted June 19, 2022 I’d love any help working through a puzzle. My 2006 Arctic spa began having trouble when the topside buttons stopped working. The filter cycle would still run ok. But now that isn’t happening - but the spa light is staying on. I unplugged the topside control from the board and plugged it into a port for an optional auxiliary topside. This gets pump #1 running on top speed when the power is turned back on. This runs for 20 mins or so, but the normal cycles do not follow. I would just buy another topside control, but I don’t want to risk a new one if the control board is bad. Any advice? If I need to replace both topside and the board, any advice on a cost-effective option? It’s a gecko system in there now, but I’m assuming I could make a change if i replace the bird and the topside at the same time. Any advice valued! Thank you! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 20, 2022 Report Share Posted June 20, 2022 Post pics of topside, circuit board and schematic on inside cover. Try disconnecting the topside and power up again without it and see if it runs low speed start up. Quote Link to comment Share on other sites More sharing options...
ArcticCub Posted June 20, 2022 Author Report Share Posted June 20, 2022 Thanks. I’ll grab some pictures. I did try disconnecting the topside and running it - but it doesn’t run a low speed startup cycle… nothing happens Quote Link to comment Share on other sites More sharing options...
