Freeflow Azure Premier pump issue
Jt4104
Freeflow azure premier will turn on and attempt to prime. Jets will come on for about 5 secs, turn off and on again. Then high jets turn on for about 5 secs and then pump shuts itself off and FLO code comes on. It was upgraded to 220v. Any thing I have missed, control panel was changed to reflect 220v upgrade
Are you in North America or Europe?
If it was originally wired as a 120V I need you to verify the pump is still 120V and not 240V. If the pump is still 120V you need to move the white wire from the pump over to P19. See pages 10 or 11. Not sure about that grey wire @ k5 going to P16 but think it's for a pump 2.
 http://www.geckoalliance.com/Documents/inyj_techbook_a_en.pdf
