Jessdodge Posted May 23, 2022 Report Share Posted May 23, 2022 My hot tub is not draining I Have done all the instructions and the water is not comming out of hose Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 23, 2022 Report Share Posted May 23, 2022 Need a bit more info. Who's tub? Does it have a valve on the factory drain? Can you post up pictures of the equipment area including the drain assembly? In all honesty, you are much better off with a pump than using the factory drain. The pump will empty the tub much faster and eventually, when using the factory drain, it will leak. A sump pump works well or you can get a pool siphon and use that. Quote Link to comment Share on other sites More sharing options...
