Breene Posted May 11, 2022 Report Share Posted May 11, 2022 hello all anybody have an idea what would cause this behavior? bought a new house and adopted an (i believe 2018) master spas clarity balance 7 spa. I'm just now working on getting it going, drained it refilled cleaned etc. part of the control panel screen was dead so you could only read some of the temp digits but it was workable. now I'm noticing after a day or two the buttons stop responding, screen stays frozen, whatever mode the spa is in when it freezes it stays in (off, or filter running). If i trip the breaker and turn it back on it comes back normal. Is it possible the control panel could cause that or is it the board ? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2022 Report Share Posted May 11, 2022 You need to replace the topside anyway so I would start there. Post photos of the topside so we can see what you have and there might be a cheaper generic replacement available. 1 Quote Link to comment Share on other sites More sharing options...
Breene Posted May 11, 2022 Author Report Share Posted May 11, 2022 7 hours ago, CanadianSpaTech said: You need to replace the topside anyway so I would start there. Post photos of the topside so we can see what you have and there might be a cheaper generic replacement available. good point and thanks. ever seen a generic for one of these ? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2022 Report Share Posted May 11, 2022 Search Balboa TP600 55673. Generic: https://www.spadepot.com/Balboa-TP600-Topside-Spa-Control-6-Button-55673-P3089 https://spapartsdepot.com/balboa-hot-tub-spa-control-panel-tp600-bp-6-button-55673/ Master Spa/Clarity Spa Price is not bad though. https://www.masterspapartsonline.com/products/master-spa-x509101-clarity-overlay-for-tp600-panel.html https://www.masterspapartsonline.com/products/master-spa-x310191-topside-control-panel-tp600.html Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 11, 2022 Report Share Posted May 11, 2022 It should be a Balboa top side. Post up the wiring diagram and spa pack pictures so we can advise you which top side to get. 1 Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 11, 2022 Report Share Posted May 11, 2022 Could be this one too. https://www.masterspapartsonline.com/products/master-spa-x310196-topside-control-panel-mp20-topside-with-overlay.html?gclid=CjwKCAjwve2TBhByEiwAaktM1Piik5DJNKUFxTc8p8T4iD3SO2H-BL2esqbyRAGpvQUSV6NK5lOqKBoC02sQAvD_BwE That's why identifying your pack is important. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2022 Report Share Posted May 11, 2022 Just use a flat head screwdriver (or 2) and pry the old one up. It is held in with a sticky backed foam. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2022 Report Share Posted May 11, 2022 2 minutes ago, cranbiz said: Could be this one too. https://www.masterspapartsonline.com/products/master-spa-x310196-topside-control-panel-mp20-topside-with-overlay.html?gclid=CjwKCAjwve2TBhByEiwAaktM1Piik5DJNKUFxTc8p8T4iD3SO2H-BL2esqbyRAGpvQUSV6NK5lOqKBoC02sQAvD_BwE That's why identifying your pack is important. The Master Spa one I posted is correct for the MS Clarity Spa series with the matching overlay but yes it is always important to know the Year of Manufacture, what spa pack and what type of connection to the pack (phone jack, Molex). Always best to confirm with the seller by phone it is correct and that they actually have in stock. Quote Link to comment Share on other sites More sharing options...
Breene Posted May 12, 2022 Author Report Share Posted May 12, 2022 21 hours ago, CanadianSpaTech said: The Master Spa one I posted is correct for the MS Clarity Spa series with the matching overlay but yes it is always important to know the Year of Manufacture, what spa pack and what type of connection to the pack (phone jack, Molex). Always best to confirm with the seller by phone it is correct and that they actually have in stock. Thanks I ordered the one you posted (non generic) My cycle the breaker trick stopped working since my first post and the screen looks worse than ever So I am fingers crossed I've just witnessed the panel slowly die in stages and Its not more complicated. The pump cycles on and off for the filter so the whole thing isn't dead. Quote Link to comment Share on other sites More sharing options...
Breene Posted June 8, 2022 Author Report Share Posted June 8, 2022 sorry for the old bump but I hate when you google problems like this and the OP never comes back! Everything is perfect after changing the topside master spa panel. confirmed it CAN cause the intermittent odd behavior I was experiencing. Thank you 2 Quote Link to comment Share on other sites More sharing options...
