Nature2 imitation?
Sid
I'm going through a little bit of a learning curve with my new spa, after 25 years we had to replace our old one. It didn't owe us anything. Said new spa came with an Ecopur mineral filter inside the pleated paper filter, and it said not to use Bromine with it. I think Ecopur uses Cu and Zn for mineral disinfection. I balked at replacing it with an Ecopur and instead purchased an inexpensive mineral sanitizer from eBay that I think is a copy of Nature2 (see attached photo). It's got some resin beads inside which I presume are impregnated with silver and/or Copper, and has worked well with the low (1-2ppm) chlorine levels I've been maintaining. I've had no clarity issues. It comes from China (I hate that, but the Nature2 probably does as well, probably from the same manufacturer). I've not been able to find information about this product to be able to determine if I can switch back to Bromine with it, and I never understood why the Ecopur was not supposed to be used with Bromine in the first place. Does anyone have any insight into this?
TIA
Sid
  • 1 month later...
If it says you need to use chlorine then you can't use it with bromine. Most chlorine only mineral cartridges use silver nitrate as the source of silver, spa cartridges normally do not contain copper because of increased chance of copper staining and green hair at the elevated temperatures seen in spas vs pool. Some do contain zinc, which is similar to copper in its algaestatic effect.
Cartridges designed for use with bromine, such as the original SpaFrog, use Silver Chloride in a calcium carbonate matrix instead of Silver Nitrate since silver nitrate will react with the bromine sanitizer to cause silver bromide to precipitate out of solution and cloud the water at best and cause silver staining at worst. Silver stains are impossible to remove.
