exeleon Posted April 24, 2022 Report Share Posted April 24, 2022 Hi all, New spa owner here. I noticed today a slow leak (a drop every 30 to 60 seconds) where this tube connects to the pump. I'm assuming there is some seal that is in need of replacement or fitting itself just needs some adjusting, but I'm not sure. My questions are, is it possible to remove this fitting without completely draining the spa? Should there be a seal in there I should be looking for? Any insight on where to start would be appreciated! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 24, 2022 Report Share Posted April 24, 2022 Yes there is an o-ring or a gasket o-ring in there. You can use a flat head screwdriver and a small hammer and gently tap on the nubs to tighten if you don't have an oil filter wrench. I don't see a gate valve plumbed in so you would have to drain the spa to replace the gasket/oring 1 Quote Link to comment Share on other sites More sharing options...
exeleon Posted April 24, 2022 Author Report Share Posted April 24, 2022 16 minutes ago, CanadianSpaTech said: Yes there is an o-ring or a gasket o-ring in there. You can use a flat head screwdriver and a small hammer and gently tap on the nubs to tighten if you don't have an oil filter wrench. I don't see a gate valve plumbed in so you would have to drain the spa to replace the gasket/oring I just lightly tapped it with a flat head screwdriver like you suggested and was able to get the fitting to clamp down a little harder on the o-ring. Hopefully that's just enough to stop the drip. Thanks for the suggestion! Quote Link to comment Share on other sites More sharing options...
Cusser Posted April 25, 2022 Report Share Posted April 25, 2022 Great. I'd get a strap wrench, a curved-jaw oil filter wrench, or a curved Vise-Grip type wrench for future "expeditions". Quote Link to comment Share on other sites More sharing options...
