HLK Posted February 11, 2022 Report Share Posted February 11, 2022 My 12 year old Hot Springs Vanguard hot tub has a flashing red power light on the controller. It also has a red light on the ic board that indicates an un-plugged controller. In the past I have replaced the small circulation pump which is now working properly, I replaced the heaters and the heater control board a couple of years ago. I have disconnected and reconnected the LED lights and this did not correct the problem. I have jumped the pressure switch and that didn't make a difference, I have jumped the high limit switch and that didn't work. I bought a new controller and that didn't change anything. I have disconnected the light and jet controller on the inside of the tub and that has had no effect. What the heck am I missing??? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted February 11, 2022 Report Share Posted February 11, 2022 If you bought a new control head, it's probably the board. Not all controls are compatible. Are you sure you got the right one? Verify incoming voltages and wiring, then get a new one. @castletonia, am I missing something? Quote Link to comment Share on other sites More sharing options...
castletonia Posted February 13, 2022 Report Share Posted February 13, 2022 There was an electronic change in the 3rd quarter of 2009. Would need to know what electronics were dealing with first. Just for the heck of it, I would unplug the auxiliary control panel. Sometimes when those go bad they create other problems. 1 Quote Link to comment Share on other sites More sharing options...
