homespaguy Posted January 21, 2022 Report Share Posted January 21, 2022 Long story short, had a 6 person spa for 15 years until the frame got rotten, leaks, needed a cover, and finally lightning hit the controller. I had just put a new pump in 2 months ago. I got a 2000 3-person LA Spa to replace it. I had trouble getting the new one up to temperature without tripping the GFCI. I attributed this to just startup issues from sitting/bad controller (there is another post about this). It went 18 days without tripping once it got up to temp, but yesterday I found it was the pump causing it. So I had a practically new 115V 1.5HP pump on hand. After I got it out, the LA Spa had a 230V 3HP pump. The voltage was easy with just swapping 1 wire. I put it in so I didn't have to drain it. This morning sitting in it the jets are not as strong on high as before but I kind of like it that way. I don't really need a bunch of violent jets, just hot water moving around makes me happy. It appears I am going from 210GPM to 155 GPM on high. So the question is, does it hurt anything to have a pump that is half the horsepower or will I just have less jet performance than before? I could see doubling the HP might cause issues, but I don't see where halving it will. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted January 21, 2022 Report Share Posted January 21, 2022 It will affect the jet performance, which you already knew. The only thing that I might be worried about would be enough flow for the flow switch. I don't think it's enough difference to have issues but it's something to watch. 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted January 21, 2022 Report Share Posted January 21, 2022 It should be fine. 1 Quote Link to comment Share on other sites More sharing options...
