Njhottub Posted January 13, 2022 Report Share Posted January 13, 2022 Hi; I just started up my new hot tub. Once filled and the jet started, a small amount of Antifreeze came out of the jets. It's hot tub non toxic antifreeze Is that an issue? Quote Link to comment Share on other sites More sharing options...
skyburn Posted January 16, 2022 Report Share Posted January 16, 2022 I don't personally know the answer to your question, but I suspect you're fine. Note the advice on starting up a winterized hot tub on this page: https://hottubownerhq.com/can-you-put-antifreeze-in-a-hot-tub/ The suggestion is to shock your tub with extra chlorine/bromine to "neutralize the antifreeze" then drain/refill. But I would think that if it's propylene glycol-based antifreeze and not a lot of it, I would think you're fine as that's food-safe stuff. Hope that helps Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted January 17, 2022 Report Share Posted January 17, 2022 No problem. Gallons of it are in every pool every spring. Quote Link to comment Share on other sites More sharing options...
