Susanj Posted December 26, 2021 Report Share Posted December 26, 2021 We had some family at our property and one night they went to get in and the hot tub temp had dropped 10 degrees. The circuit apparently had tripped. Now I worry if that happened when nobody was there in winter, it could freeze and ruin it. Has that happened to anyone? Quote Link to comment Share on other sites More sharing options...
Cusser Posted December 26, 2021 Report Share Posted December 26, 2021 This would be way over my technical expertise. but looks like their are Wifi temperature monitors available https://www.google.com/search?q=wifi+temperature+monitor+for+spa&source=hp&ei=I3PIYfbeCNqt0PEP7JaWyAY&iflsig=ALs-wAMAAAAAYciBMwhU325SrbZ3hJgFFqdNHYIRgzlX&ved=0ahUKEwi2_Ov2zYH1AhXaFjQIHWyLBWkQ4dUDCAg&uact=5&oq=wifi+temperature+monitor+for+spa&gs_lcp=Cgdnd3Mtd2l6EAMyBggAEBYQHjIGCAAQFhAeMgYIABAWEB4yBggAEBYQHjIFCAAQhgMyBQgAEIYDOgUIABCRAjoKCAAQsQMQgwEQQzoRCC4QgAQQsQMQgwEQxwEQowI6BAgAEEM6CwgAEIAEELEDEIMBOg4ILhCABBCxAxDHARCjAjoICAAQsQMQgwE6BAguEEM6CAgAEIAEELEDOgcIABCxAxBDOgUIABCABDoJCAAQyQMQFhAeUABYi1RgtFhoAHAAeACAAbACiAGPHpIBCTE0LjE0LjEuMZgBAKABAQ&sclient=gws-wiz Quote Link to comment Share on other sites More sharing options...
Susanj Posted December 26, 2021 Author Report Share Posted December 26, 2021 Thank you. I am wondering why this happens- what might cause it to trip , and how long it might take to freeze. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted December 26, 2021 Report Share Posted December 26, 2021 I replied to your other post. On a fully insulated tub on the ground you can go days with no damage, and the first things to freeze will be in the equipment area. On a deck you lose a day or 2. Not full-foam and it can freeze pipes in hours. Gfci breakers trip for many reasons. Often it is the breaker itself, or loose connections on the breaker. Most things in the spa will trip it repeatedly, but not always. Nuisance tripping is the most difficult issue to troubleshoot in a spa. 2 Quote Link to comment Share on other sites More sharing options...
