eric61 Posted December 21, 2021 Report Share Posted December 21, 2021 Hello- I have successfully and happily been using the dichlor/bleach method for about a year, and it has been easy and perfect. However, we now find ourselves away during the week most weeks due to my wife's job, back on weekends. I have been shocking the tub with chlorine (I usually get 10% pool chlorine from Walmart) to around 12-16ppm and hoping for the best. Most times I come back and the FC is not 0 so I bring it up to 8 or so then use it all weekend. But sometimes it is 0 with slightly cloudy water and it takes awhile to shock clear. Note the CCs are always less than .5 (often .2). I use a Taylor kit fwiw. CYA is 30 and Ph is pretty stable (sometimes it has creator to 7.8-8 but an oz of acid brings it back, TA stays at 79 or so). My question is: would I be better switching to the @ease system? My wife is sensitive to MPS so I would need to use chlorine shock. However, I hate to switch away from a system that I understand. Thoughts? Quote Link to comment Share on other sites More sharing options...
FROG Products Posted December 22, 2021 Report Share Posted December 22, 2021 Hey – sounds like you take good care of your hot tub. Using FROG @ease will allow you to leave for a week at a time, return, and find your hot tub water just right. It’s an easy system to use too. If you’d like to learn more, email or call Dan at dan.mosier@kingtechnology.com or 800-222-0169, he can answer your detailed questions. Check out frogproducts.com or this video on FROG @ease for helpful tips: https://www.youtube.com/watch?v=z7_2rMH3xME We’ve got other videos too on how to fix cloudy water, how to fix foamy water, all on You Tube. We hope to hear from you! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted December 22, 2021 Report Share Posted December 22, 2021 I like mineral purifiers, but use them with traditional chlorine. The @ease system uses smartchlor, if I'm not mistaken, which from what I hear gives some strange test results and some people struggle with it. I have never used it myself, but have had great results with the "mineral sticks" that go in your filter when used with a dichlor/bleach method (mostly dichlor, as I drained frequently) and 24/7 ozone injection. It is the system I recommend to customers and have used myself for over a decade. Quote Link to comment Share on other sites More sharing options...
