Need some fedback on improving hot tub energy efficiency
Sportguypro
Hi All,
I have an in-ground hot tub with two pumps, pump#1 (a super pum) for the filter/gas heater and pump#2 (a variable speed pump) for the jets. The specs are at the bottom of the post. I would like your feedback on how to increase efficiency and not waste electricity.
Currently, pump#1 runs 24/7 and pump#2 only runs when we use the hot tub (once a week). Pump#2 (variable speed pump) is very efficient, but pump#1 (super pump) is constantly running at full RPM making it expensive on the electric bill. I can manually turn off pump#1 and make it run for certain hours of the day but during the winter season, since the gas heater is outside, I cannot let the water inside the heater freeze.
I was thinking of two solutions:
1) Buy a Variable speed pump to replace the super pump and program it to constantly run at the lowest RPM and occasionally increase RPM so the heater can run. ($2K)
2) Buy a OMNI automation controller system so it can control the pumps. ($not sure of the cost)
I am trying to find a way that so I dont have to be involved on a day to day basis.
Thanks in advance for your feedback!
Sportguypro.
Hot tub:
500 Gallon in-ground Hot tub.
Jets:
Pump#1: Hayward Ecostar Variable Speed Pump
  • Specs: 230V (60HZ) 10.9 Amps    RPM: 600-3450
Heating & Filtration system:
Pump#2: Hayward Super Pump 1/2 HP Model C48D45A04
  • Specs: 230V 5.5 Amps
Filter: Hayward Xstream Model CC150CAN Cartridge filter
Heater: Hayward Gas Heater H250  Model:H250PED2
  • Specs 250,000 BTU
  • Sportguypro changed the title to Need some fedback on improving hot tub energy efficiency
