Gecko YE-3-CE IN.YE-3-H3.0
Michal
Hi,
I just got my first hot tub and I am super exited about. Since I am located in south Poland we have a pretty cold winters and I need some help. I have a CP running 24/7 and I cannot change it with my in.k800 .
My setup is :
2 x 3hp pumps
1x UV
1x Ozone
1x Blower
1 x CP
Two 3HP pumps and a blower  are connected to A1 A2 A3 and CP With Ozone is connected directly to the board.
My question is : Is there any anything I can do so my CP won't be on 24/7 and I can set up filter cycles with my in.k800?
P.S . I made a huge mistake buying from a dealer that has no idea about hot tubs and is selling garden equipment. Sorry for my english as well:)
1 hour ago, CanadianSpaTech said:
See page 2 below
https://issuu.com/geckomkt/docs/inye3_ye5_ce_qsc_en?e=14165552/44051896
You might also want to contact Gecko Europe to verify what Lower Level (LL #) setting will work best for your spa and how you want to set it up
https://gdeuro.com/contact-us
CanadianSpaTech….. can you HELP!
My Hydropool Serenity 5000 after running for 30 minutes (works perfect) trips the main 100 amp breaker feeding my sub panel where my spa is fed from?
Seems like it’s calling for another pump to come on it something with a short in it?
I haven’t tried cleaning the filter yet, just thought of it tonight.
can you help????
20 hours ago, CanadianSpaTech said:
See page 2 below
I have 338 rev.3 software , I don't have LL option like on the pdf you posted, do you think upgrading my soft to rev. 10 would help?On the pic below , you can see where my CP is connected (N to p57 , L to P51)
You might have to upgrade to get what you want https://issuu.com/geckomkt/docs/instik_upgrade_spa_en/1?e=14165552/32069580
I would contact Gecko Depot Europe before buying to see if it can be done without having to upgrade the software. Their tech support is usually very helpful. The spa manufacturer might have their own programming installed to make the pack proprietary to them.
