2003 Tiger River Bengal M - No Heat/tripped 30A/flashing READY
Current issue is a 2003 Tiger River Bengal M that has no heat. Below are the symptoms and repair history associated with it:
- Panel will show the flashing READY with 2-3 minutes after resetting the breakers in the panel. Circ pump, ozonator and jet pump continue to function as normal.
- When setting 30A breaker in panel to ON position, it will sometimes drop to the tripped position 1-2 times before staying in ON position
- Heater relay board was replaced in April 2020 with P/N 77119 (newer 2 relay design). Main control board was replaced in June 2021 with P/N 77087.
- Heater assembly is original to the hot tub (Watkins twin tube No-Fault)... so it's nearly old enough to vote.
- Heater HAS WORKED since the last board was replaced in June 2021
- Spa is wired for 230V, 30A for heater/20A for jet pump
Although the boards are relatively new and the heater is old, I still would like to go through the proper diagnostics to verify the heater has failed. Where is the best place to start?
Thanks in advance for any advice you have!
Remove filters. Post pics of circuit board, wiring diagram, and equipment area.
A tripped breaker must be flipped to the off position before resetting. Check and tighten breaker wire terminals. How often does it trip?
I'm pretty sure it did...😉
Post those pics.
Quote
I'm no expert but it sounds like your spa is possibly going into protection mode due to faulty (or failing) temperature sensors.
If you have a multimeter I believe you can test the impedance of the sensor to see if it has continuity (should be in the 10k to 15k range if I'm not mistaken, but I could be wrong).
Yes, I have a multimeter. I have not replaced the sensors, so that's a good thing to consider.  I'll check them out.
Quote
Post those pics.
- Filter is out. I will get pics of the boards, diagrams and eq. area this weekend
- I pulled the breakers out of the box and inspected them. All connections are tight.
- The 30A breaker doesn't trip when the spa is in use. When the spa display starts flashing READY, I'll switch the breakers to cut the power and that's when the 30A will need 2-3 tries to get it to stay in the ON position. During the 18 months we've lived at this house, neither the 30A or 20A has ever tripped on their own accord.
Thank you both for the assistance and I'll report back when I have some more data!
