Chuck77 Posted November 11, 2021 Report Share Posted November 11, 2021 I need advice on a repair to my in-ground pool. As you can see in the pics below, the outer shell of my pool has been eroding away in several spots due to water leaking down from above. The concrete patio, which I have just removed, had been sinking and causing rain water to puddle up against the outer edge of the coping. The pool mastic was cracked and this allowed the water to seep down between the pool and the patio. It looks like this water was causing the outer shell (adjacent to the soil) of the gunite to erode away. I was able to chip away the loose pieces and used compressed air to clean out most of the dirt and other loose debris. I plan to pour a new concrete patio but first I’m thinking I should probably patch these damages on the pool. I was thinking of using a mixture of 1:2 Portland cement/sand but I’m not sure. Looking for suggestions. Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
Edith martin Posted November 11, 2021 Report Share Posted November 11, 2021 I may have the same problem as I have water leaking from somewhere . Water in a ditch I dug out on that side has water in at at all times and side of hot tub is wet. If anyone knows someone who can find the leak and fix it Help! I already replaced pebble tech inside Quote Link to comment Share on other sites More sharing options...
