Umair Posted November 6, 2021 Report Share Posted November 6, 2021 Hi, I have a Marquis Euphoria spa and I have it on in the sleep mode and temperature set at 26 degrees. almost every day the water level in the spa drops. I have to fill it up after 2 days to make sure that the water does not drop below the filter openings. I tried to look for water leakages outside but couldn’t see any apparent ones. Could you please advice what to do here. thanks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 7, 2021 Report Share Posted November 7, 2021 Turn on all the jets and open up the main panel first and check around the pumps for leaking pump seals. If the equipment area is dry then continue opening side panels and keep looking. Quote Link to comment Share on other sites More sharing options...
Umair Posted November 16, 2021 Author Report Share Posted November 16, 2021 I opened up the equipment area (place where the motor is) and found that the screw on the motor was leaking water. I’ve tried to screw it tight but it has not fixed the issue. video is attached IMG_1361.MOV hed Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 17, 2021 Report Share Posted November 17, 2021 No Vid Quote Link to comment Share on other sites More sharing options...
Umair Posted November 17, 2021 Author Report Share Posted November 17, 2021 Sorry. Don’t know why the media player is not showing it. so I uploaded on YouTube instead: can yiu see it now ? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 17, 2021 Report Share Posted November 17, 2021 Yes. It can be seen dripping at the screw but it looks like it is coming from higher up. There is 2 possible o-rings that can be replaced that will likely stop the drip. There is an o-ring in between the white coupler and the black face of the wet end. There is also an o-ring between the face of the wet end and the body of the wet end. You would need to remove the face of the pump and would be easiest to drain the spa and remove the pump to do it. You could try to close the gate/slice valves and crimp off or plug the 2- 3/8" lines but the slice valves often don't hold back the water 100%. Let us know results Quote Link to comment Share on other sites More sharing options...
Umair Posted November 18, 2021 Author Report Share Posted November 18, 2021 Thank you for the feedback. I will try it out and let you know. Quote Link to comment Share on other sites More sharing options...
Cusser Posted November 18, 2021 Report Share Posted November 18, 2021 On 11/17/2021 at 6:22 AM, CanadianSpaTech said: Yes. It can be seen dripping at the screw but it looks like it is coming from higher up. There is 2 possible o-rings that can be replaced that will likely stop the drip. There is an o-ring in between the white coupler and the black face of the wet end. There is also an o-ring between the face of the wet end and the body of the wet end. You would need to remove the face of the pump and would be easiest to drain the spa and remove the pump to do it. You could try to close the gate/slice valves and crimp off or plug the 2- 3/8" lines but the slice valves often don't hold back the water 100%. Let us know results This. And I also have found that the slice valves won't hold back all the water. Quote Link to comment Share on other sites More sharing options...
Umair Posted November 25, 2021 Author Report Share Posted November 25, 2021 Hi, I spend some more time to examine the fault and you were right. It does come from higher up. if you look in the video below, you will see that the water is leaking from a ring further up. This is not a place for the screw (I don’t know what it is). could you please share your opinion on this. do you still think the solution is an O ring ? adding two videos and also a picture of the pump taken from the net. video 2: technical image of the pump : Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 26, 2021 Report Share Posted November 26, 2021 Looking at the second video there looks to be a crack in the suction cover 91231606. The hole where the water is dripping should be closed off and no water should be able to escape from there. I would be replacing the front cover of the wet end. 1 Quote Link to comment Share on other sites More sharing options...
