labvt3 Posted October 22, 2021 Report Share Posted October 22, 2021 I have a 2011 hot springs jetsetter and when plugged in the jet pumps instantly turn on and no controls on panel will work. Company came out tried new heater board that didn’t work. There conclusion was voltage drop issue. Electrician came out 117v and 17 amps at tub while motor is running. No expert but he thought probably tub issue. Any idea on where I can start trouble shooting. Thank you. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted October 22, 2021 Report Share Posted October 22, 2021 Sounds like the topside controls are bad. 1 Quote Link to comment Share on other sites More sharing options...
labvt3 Posted October 23, 2021 Author Report Share Posted October 23, 2021 One thing I was thinking. Plug spa in started circulating fine. Pressed jets and pump had trouble starting. Believe due to airlock. Finally pump kicked on but now no controls. Just partial screen power light and spa lock symbol. I will investigate controls further. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 23, 2021 Report Share Posted October 23, 2021 edit Quote Link to comment Share on other sites More sharing options...
ratchett Posted October 23, 2021 Report Share Posted October 23, 2021 23 hours ago, labvt3 said: Company came out tried new heater board that didn’t work. There conclusion was voltage drop issue. Which company came out? Was it a Hotspring authorized dealer, or just some general spa repair technician? When they replaced the board, did they replace the topside controller? Because I'm pretty sure that generation of spas has an issue where the OEM brand for the control boards went out of business and Hotspring sells a new control board and topside controller for those spas - replacing the one without the other might be the issue. So that's why I question if it was actually a hotspring technician or just some general spa repair guy who doesn't know the specific inner-workings of a Hotspring spa. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 23, 2021 Report Share Posted October 23, 2021 32 minutes ago, ratchett said: or just some general spa repair technician Ouch that hurts 2 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 24, 2021 Report Share Posted October 24, 2021 13 hours ago, CanadianSpaTech said: Ouch that hurts Right? From "Spa Guru" to "just some guy" like THAT! 2 Quote Link to comment Share on other sites More sharing options...
labvt3 Posted October 24, 2021 Author Report Share Posted October 24, 2021 It was a repair guy from the spa place where it was purchased from. Did not have a good feeling he knew what he was doing. Said changed heater control board did nothing. So put old back in. Said he saw voltage dropping off at spa down to 100v and that was why pump not working. But pump works. That’s the only thing that works. Display did say protection mode once when you could get a descent view. ASL how to take it out of protection mode. Said you can just unplug it for a minute and just plug it back in. It’s been unplugged for days and just turns pump on as soon as it has power. So most likely this is a control board issue. When’s over it no sign of corrosion and don’t think a solenoid is stuck. Anyone no how to reset this spa so I can at least get some heat to it. Temperature are getting cool around here so pretty soon just drain it till the spring. Quote Link to comment Share on other sites More sharing options...
