Kennymact Posted October 10, 2021 Report Share Posted October 10, 2021 Hi people. Just bought a secondhand spa leisure rite Has a pump which says it is two speed. It seems to only have one speed. How do I check if it is two speed? It has four wires from pump to circuit board. I thought it should be low speed running but go to high pawed week jets are selected ? Any help or info welcome. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 10, 2021 Report Share Posted October 10, 2021 12 minutes ago, Kennymact said: It has four wires from pump to circuit board. Would usually indicate a 2 speed pump. If it runs in high speed can you then step it down and it will only then run in low? Should have a white tag/sticker on the pump. Post pic. Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 10, 2021 Author Report Share Posted October 10, 2021 Only these two stickers on there. Only way to try the low speed is to possible check that it is wired correctly. From back of pump to circuit board Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 10, 2021 Report Share Posted October 10, 2021 2 speed. Post photos of the circuit board and the schematic on the inside cover if there is one. If you turn on main power and let it run through prime mode do you then get an error code? Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 10, 2021 Author Report Share Posted October 10, 2021 I ll take a picture of the schematics later today. IMG_5473.MOV Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 10, 2021 Report Share Posted October 10, 2021 Did you remove Jumper A? Was it previously set up to run at 16 AMP or 32 AMP? Check the dip switch settings (little red box in last photo) and make sure it is set properly as per the instructions on the schematic. Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 10, 2021 Author Report Share Posted October 10, 2021 Not removed jumper a. on start up no error messages. Checked the selected pins in the red box and all seem ok I did tur power off and select to run pump on button 5 to a different position hoping it would run the pump at a slower speed but no change so went back to original position according the schematic Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 11, 2021 Report Share Posted October 11, 2021 Where the wires go into the circuit board there is a white tag that says remove jumper A. Will need to see schematic. I am not all that familiar with your power gird so... Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 11, 2021 Author Report Share Posted October 11, 2021 Here some more pictures. Hope this helps. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 11, 2021 Report Share Posted October 11, 2021 Again I know little about European power grid but the white tag where the main power wire goes in to the terminal block says remove jumper A. Jumper A looks to be the black wire going from J32 to J 26 Quote Link to comment Share on other sites More sharing options...
cranbiz Posted October 11, 2021 Report Share Posted October 11, 2021 DIP Switches look correct. It's wired into Service 2. According to the wiring diagram, remove Jumper A for service 2 and it sure looks like Jumper A is connected to J32. @CanadianSpaTech is spot on with his observation. Perhaps, at one point, it was wired for a 33A circuit. Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 11, 2021 Author Report Share Posted October 11, 2021 So have killed the jumper off and turned it on. Ran thru cycle check ok and is now warming the water up but at the same speed as before. I turned on jets and blower but no change in speed. I’ll see if I can make a video of the noise of the pump and maybe you can deduce something from it. Mate it’s normal to sound this loud. Also I’ll be checking the electric usage as the power company e mailed me to tell me my power usage had doubled since I’ve been using the spa. might start cracking pipes open in case air is in the system 65568705835__0F0D0670-1D1B-42CC-AEE0-323D11E1066C.MOV Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 12, 2021 Report Share Posted October 12, 2021 No photo/video Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 12, 2021 Author Report Share Posted October 12, 2021 Mmm video works my end. I’ll try again 1048741865_Runningspa.MOV Quote Link to comment Share on other sites More sharing options...
Kennymact Posted October 12, 2021 Author Report Share Posted October 12, 2021 Also since I have removed the jumper the heater is not working. The heat pump light is on but not heating. Also have always had air coming from the massage jet. Not sure if that’s an air lock or air getting sucked into the system. ? Might start cracking unions around pump to see if air is trapped ? Clutching at straws here. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 12, 2021 Report Share Posted October 12, 2021 8 hours ago, Kennymact said: Also since I have removed the jumper the heater is not working Ok put it back then. You are going to have to check for hi and low speed power coming off the circuit board where the pump connects to the circuit board with a multi meter to see if it is a pump issue or a circuit board issue. GS501 Tech Manual here: https://www.vortexspas.com/_vortexspas/Library/Support/Balboa-GS-501-Spa-Controller-Tech-Sheet.pdf https://www.spastore.com.au/assets/files/Balboa GL and GS Spa Control Troubleshooting & Service Manual 230V Part 1.pdf Quote Link to comment Share on other sites More sharing options...
