Crush23 Posted October 8, 2021 Report Share Posted October 8, 2021 Hello peeps, I'm new to this forum. I have a problem with my spa. I noticed last week my jets weren't working. My #1 pump works like it should but my pump #2 doesn't work, all I hear is a click from a relay. I took the 2 fuses (sc-25)s out and ohm'd them and found one that isn't good. My question is to you guys, should I just replace the fuse and hope that is the problem or do you think there is another problem that caused the fuse to blow? Any input is welcome and appreciated. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 8, 2021 Report Share Posted October 8, 2021 2 pumps 2 fuses swap places and if the relay still clicks you have bigger problems. If the non working pump now works replace fuse. If it blows that fuse.. again you have bigger problems. Likely a stuck pump impeller. Let us know if the fuse swap works or if you need further assistance. Quote Link to comment Share on other sites More sharing options...
