Mystery hole
steel_j
It is a flow jet that is likely hooked up to your ozone and or heat line. I would be looking hard at those pin light bezels for leaks. You will need to get to the backside of that jet if that is where it is leaking. There is a nut on the backside of the jet that can be backed off enough to be able to push the jet forward a bit so you can clean up any old silicone or seal material on both the bather side as well as the inside of the cabinet. Then slather marine grade silicone on both sides and re tighten the nut to compress the silicone. Tighten but Do not over tighten.
