marcusa Posted September 27, 2021 Report Share Posted September 27, 2021 Hi all, I have a 2005 Great Lakes Forte hot tub witha Balboa GVS500. When I turn my spa on, the only message I can receive on the display is six -'s. Here's a pic: https://imgur.com/a/vApj8Vl There's no information about this error code in the manual and I can't find anything online. Everything else seems to work though. The jets and heater work. When I turn it on, it gets to temp. I'm guessing it's just running in some default mode. I've tried unplugging the top control and turning it back on. When I do that, nothing runs. I've also tried resetting the temp sensors by unplugging them and turning the tub on. I can't get this error code to go away and just get it to display the temp. I'd like to do something besides just throwing parts at it, although if I can't figure it out I'll suppose I'll just start with replacing the topside display and the sensors if there's no better way to go about it. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 27, 2021 Report Share Posted September 27, 2021 A balboa system should run automated functions with the topside unplugged. The fact that yours does not suggests it is not the topside. I would test incoming voltage and sensors, and if those are good, it's probably the board. Post pics of circuit board and wiring diagram. 1 Quote Link to comment Share on other sites More sharing options...
marcusa Posted September 29, 2021 Author Report Share Posted September 29, 2021 On 9/27/2021 at 10:59 AM, RDspaguy said: A balboa system should run automated functions with the topside unplugged. The fact that yours does not suggests it is not the topside. I would test incoming voltage and sensors, and if those are good, it's probably the board. Post pics of circuit board and wiring diagram. Thanks for the response. Here are pics of the board and diagram. I tested the sensors in 80degree water and the only reading I could get was with my ohmeter set at 200k each sensor was reading about 22.7. What voltage are you saying to test? The incoming 240V to the board? I'm pretty sure that's good because I have power to the jets and heater just fine. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 29, 2021 Report Share Posted September 29, 2021 https://www.google.com/search?ie=UTF-8&client=ms-android-uscellular-us-revc&source=android-browser&q=balboa+sensor+resistance+chart#imgrc=HRmzsRpemdUsIM 40 minutes ago, marcusa said: I'm pretty sure Not good enough. Test voltages, both 240v and 120v (red and black to white). The controls operate off 120v, and a problem with the breaker can cause low voltage to the controls, which will cause errors. Check for loose connections at the breaker and neutral pigtail too. If it comes to part-swapping, I would just buy a new system. By the time you buy a topside and board you have paid for a new system with sensors and heater as well. 1 Quote Link to comment Share on other sites More sharing options...
marcusa Posted October 11, 2021 Author Report Share Posted October 11, 2021 I tested the voltage and I'm getting 120 from each wire so that was good. I ended up just buying all new guts instead of throwing parts at it and it fixed the problem, Thanks! Quote Link to comment Share on other sites More sharing options...
akemsley2 Posted July 24, 2022 Report Share Posted July 24, 2022 Hi. I had the 6 dash error on a gs100 equivalent to a vs100 in the states. Changed topside no luck. Changed main PCB. Fixed problem. I think it's the program on the topside controller pic chip that gets corrupted and no option but to change board. I also tried a memory reset on the board without luck. Sorry expensive fix but hopefully avoids someone else buying a topside too. Quote Link to comment Share on other sites More sharing options...
akemsley2 Posted July 24, 2022 Report Share Posted July 24, 2022 Just while a remember. The topside was fully functional. Just couldn't see what you were doing with temp and settings. Quote Link to comment Share on other sites More sharing options...
