Corey Patterson Posted September 24, 2021 Report Share Posted September 24, 2021 I have a Freeflow Spa that is currently on a 120v circuit. Normally when I power the spa on, the temperature shows up and the pump kicks on low and starts heating to set temperature. Now when I power on, the temp doesn't show up and low speed pump doesn't turn on so it wont heat. However, if I turn on the high speed jets for about a minute, the temperature finally shows up and I can turn off the high speed jets, which then the low speed runs and achieves set temperature. This only works if I wait for the temp to show up before turning off high speed jets. After reaching temperature, low speed shuts back off but wont restart when temp drops and needs to heat again. Then FLO error shows up after the low speed doesn't turn on. The only way to get spa to heat again is to shut off and start again. I've replaced heater with flow sensor and then replaced the relays on the circuit board thinking they were the problem but didn't fix it. Any help where to go from here would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 26, 2021 Report Share Posted September 26, 2021 Post pics of circuit board so we can see what you have. Quote Link to comment Share on other sites More sharing options...
Corey Patterson Posted September 27, 2021 Author Report Share Posted September 27, 2021 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 27, 2021 Report Share Posted September 27, 2021 Hey @CanadianSpaTech, is that a gecko? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 27, 2021 Report Share Posted September 27, 2021 2 hours ago, RDspaguy said: Hey @CanadianSpaTech, is that a gecko? Yes a Y-?? model Quote Link to comment Share on other sites More sharing options...
Corey Patterson Posted September 27, 2021 Author Report Share Posted September 27, 2021 I'd buy a complete replacement but I can't find one with the exact same model numbers and options. Some are close but I don't know enough about them to know that they would work. I'd hate to drop $400-500 on a new control board if it's not compatible. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 27, 2021 Report Share Posted September 27, 2021 That's easy, if you don't mind changing pump cords and such. Go to spadepot.com and type in "balboa vs", then fill in the blanks about your spa. 1 Quote Link to comment Share on other sites More sharing options...
