rbertoia Posted September 20, 2021 Report Share Posted September 20, 2021 Why does sub panel have to be five feet from tub? Can i mount it between windows? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 21, 2021 Report Share Posted September 21, 2021 NEC (national electrical code) says the disconnect must be no less than 5ft, no more than 25ft, and in a direct line of sight from the spa. This is to avoid the potential of accidental electrocution and provide a visible means of disconnect for fire and safety personell. There is no code regarding windows near a disconnect, but if the square is the location of the spa then it's probably too close. The distance is as measured from the surface of the water in the spa, not the spa itself. Quote Link to comment Share on other sites More sharing options...
