Pumps replaced now have a leak from inlet/outlet end of heater
Frog1
I figured y’all would say that, RD.  Looks like there’s the OEM at 500 and another popular one for 300 aftermarket.  Aftermarket one needs to have a jumper on the board because it has an internal pressure switch and not the original board driven setup? Worth the price difference or stick with OEM?
Uhhh... ok. I've never seen a threaded pressure switch with a gasket. Unless you consider teflon tape a gasket.
I have never had one of those heaters apart so can't be sure, but I'm betting a new pressure switch will do the trick. Something like this might work.
https://pool-spa-supplies.com/caldera-spas-pressure-switch-2006-to-current-kit-ps-hohs-06-73995-3331?utm_source=google_shopping&gclid=Cj0KCQjwv5uKBhD6ARIsAGv9a-x2az-UccJqgp_jVnjiZsGKzYIR-x-pnP0Tf0DlwBKEuUDY9jPio70aApacEALw_wcB
  • Thanks 1
