contact634 Posted September 7, 2021 Report Share Posted September 7, 2021 so my tub had been 100% for months a few weeks ago I had my 2 speed pump fail (orig to 2001) the start cap went and the wet end impeller broke on removal I swapped in a spare pump and wet end I had and all was well last night I noticed the lower drain plug was leaking so i got my oring kit and tried noting would stop the leak it went form bad to worse at this point i suspect the wet end where the drain plug screws in might be cracked or damaged (cant see it) I got it down to a steady drip when pump was running I also tried the plugs from spare pumps and no go still leaks (all old orings) leak is running away from everything all electric staying dry we jumped into tub after 20 mins no problem did another 20 and my control panel went into lock mode (did this last year with remote panel plugged in, still not plugged in) got out about 5 mins tub still locked I tripped breaker still locked waited 10 mins finally unlocked seemed to work fine Ill go out later and check it I have 1 sundance dealer 45 mins away I'm going to see if they have the correct oring in stock today Now questions pump wet end plugs are plastic as is wet end is cracking common/normal (if it is cracked) its black plastic will any glues/epoxy stick to them? lock mode I did NOT touch or move any wires in the past 2 weeks I messed with the pump plug leak which is not getting anything wet except base wood Quote Link to comment Share on other sites More sharing options...
