Display LED issues with Freeflow Cascina hot tub
The topside is made by Gecko Alliance but likely proprietary to Freeflow. Post pics of the spa pack and schematic on the inside cover if there is one.
The Gecko IN.K330 is close but can't say it would work without seeing the pack.  https://geckokeypads.com/ink330overview
Hi @CanadianSpaTech, thanks for your response.
The equipment is definitely made by Gecko.  Attached is a picture of the brains of the spa and also of the keypad/screen.
I found that this company sells the replacement part, but I'm worried that exactly the same part will last exactly the same time, which was just a little over a year.
https://www.hottubspasupplies.com/catalog/product/view/id/36180/s/78453-freeflow-topside-4-button-no-overlay-1/category/2/
Perhaps I should replace it with a newer, revised, but compatible keypad/screen from Gecko?  Is that possible?
Also, would it be possible just to replace the LCD portion?
Your help is appreciated!
It looks like this one:
https://www.yseries.ca/overview-yj/
Only that mine says v2 and this one is v3.
I wonder if any of those 2 keypads would work on mine because I don't feel very comfortable going with the same keypad that did not last much.
I also checked the connector from the brains to the keypad and it seems fine, clean, etc.  Disconnecting it a few times and reconnecting it did not have any effect.
Now, what if it is not the keypad but something bad in the brains?
