Diggar Posted August 24, 2021 Report Share Posted August 24, 2021 I have a Hot Springs Sovereign II hot tub. It has a The Watkins No Fault 240 volt, 6 kw, model code SSE-00-OH-OF that is leaking at the small end caps? I have seen end caps for sale on line but I am not sure if they fit my heater. Do you of any place that sells the correct end caps or can they be repaired with some sort of adhesive, (JB Weld)? I know they are a resin so I am not sure what will stick. Any help appreciated Thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 24, 2021 Report Share Posted August 24, 2021 Some here have replaced it with a loop of clear tubing. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 24, 2021 Report Share Posted August 24, 2021 This work? https://www.spadepot.com/gasket-Kit-4-Watkins-Hot-Spring-Double-Barrel-Heater-P3111 https://www.spadepot.com/docs/Double-Barrel-Heater-Gasket-Kit-Instructions.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
Diggar Posted August 26, 2021 Author Report Share Posted August 26, 2021 I found the cap online, Amazon of all places, and ordered it. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
