Jimmymooncat Posted August 19, 2021 Report Share Posted August 19, 2021 Clear water when resting. Water goes white when jets are on? Bromine user. Quote Link to comment Share on other sites More sharing options...
Jimmymooncat Posted August 19, 2021 Author Report Share Posted August 19, 2021 Once the jets turn off the water goes clear straight away. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 19, 2021 Report Share Posted August 19, 2021 When did you last change your water? Post your chemical maintenance routine, method of testing, current readings, and all chemicals used, by active ingredient. Maybe @waterbearor @Cusserhave some ideas. Quote Link to comment Share on other sites More sharing options...
dashmer Posted August 20, 2021 Report Share Posted August 20, 2021 Sounds like dissolved air in the water from the jets....assuming you are running air with the jets. 1 Quote Link to comment Share on other sites More sharing options...
Jimmymooncat Posted August 22, 2021 Author Report Share Posted August 22, 2021 On 8/20/2021 at 1:01 PM, dashmer said: Sounds like dissolved air in the water from the jets....assuming you are running air with the jets. Yes it is air jets. I empty the hottub every 5 months. I use bromine tablets and non chlorine shock. My pH is a little low which I'm gradually getting up. Quote Link to comment Share on other sites More sharing options...
Jimmymooncat Posted August 25, 2021 Author Report Share Posted August 25, 2021 On 8/20/2021 at 12:13 AM, RDspaguy said: When did you last change your water? Post your chemical maintenance routine, method of testing, current readings, and all chemicals used, by active ingredient. Maybe @waterbearor @Cusserhave some ideas. Changed the water in May. I use Bromine tabs, non chlorine shock (every four days depending on use). Water clarification, hp up, spa sparkle and foam away ( every seven days). I just changed my filter. The one that was in was dirty. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 25, 2021 Report Share Posted August 25, 2021 On 8/19/2021 at 6:13 PM, RDspaguy said: Post your chemical maintenance routine, method of testing, current readings, and all chemicals used, by active ingredient. You should change the water every 3-4 months. Please provide the rest of the info I asked for and maybe one of our bromine fans can give you some advice. Without the details, we are just guessing. Quote Link to comment Share on other sites More sharing options...
