Aquaspa problem.... Faulty sensor? Please help!
Diane0710
Hi. I have an aquaspa inflatable hot tub. When I try to heat it up only the top few cm of wayer5 get hot and the rest is cold. On the temp gauge it says 40 which is what it is set to so it's as if it thinks that it's reached temp but the water underneath is cold. I'm not particularly savvy with these things so could do with some advice. I'm thinking maybe temp sensor needs replacing but then I don't really know. Can't afford to spend a fortune on it so looking for ideas about what could be wrong and how to fix. Thanks.
