Kira17 Posted August 16, 2021 Report Share Posted August 16, 2021 Have a hottub that the pump kicks on for a min then shuts off. Have changed board, checked pump, drained hottub while doing this and was filling hottub back up was half way full tried kicking it on and it worked perfect filled it the rest of the way up and the issue started again. Any ideas? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 17, 2021 Report Share Posted August 17, 2021 Are there any errors on the topside? Check voltage to the motor. Post pics of the equipment area and circuit board so we know what you've got in there. Quote Link to comment Share on other sites More sharing options...
ratchett Posted August 18, 2021 Report Share Posted August 18, 2021 When you fill the hottub, how are you doing it? Through the filter well, or just straight into the tub itself? Is there a bleed valve on your spa to eliminate air in the plumbing. Don't some spas have a "prime mode" which try's to prime the line by pulsing the pump? I wonder if that's whats going on here.... Quote Link to comment Share on other sites More sharing options...
