Merckaert Dimo Posted August 11, 2021 Report Share Posted August 11, 2021 Hi everybody, I've got a problem with heating my hottub. I've already changed the heater ( electricity feeling in the water). Also the pressure switch to be sure. But still no heat. And still slighty electricity feeling in fingertops.. I've checked the heater relay board on black spots but that seems ok. No fault code on the topside panel. D17 light is on (main board). Now i bought a new main board but i Think they send me a wrong one. Any opinions? (Pics attached) Hope you guys can help me. Thanks in advance Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 11, 2021 Report Share Posted August 11, 2021 If you are getting a low voltage tingle when you touch the water disconnect the main wiring from the pack and see if you still get a tingle. Let us know results. I'm not a Hot Springs guy so I will let others comment on your board issues. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 11, 2021 Report Share Posted August 11, 2021 12 hours ago, Merckaert Dimo said: ( electricity feeling in the water Your spa should be on a gfci protected circuit, and it should trip if there is the slightest "electricity feeling" in the water. Maybe @castletoniacan comment on the board compatibility. Quote Link to comment Share on other sites More sharing options...
Merckaert Dimo Posted August 11, 2021 Author Report Share Posted August 11, 2021 9 hours ago, CanadianSpaTech said: If you are getting a low voltage tingle when you touch the water disconnect the main wiring from the pack and see if you still get a tingle. Let us know results. I'm not a Hot Springs guy so I will let others comment on your board issues. Hey, thanks for your input and reaction! I will try to check this tomorrow! Quote Link to comment Share on other sites More sharing options...
Merckaert Dimo Posted August 11, 2021 Author Report Share Posted August 11, 2021 1 hour ago, RDspaguy said: Your spa should be on a gfci protected circuit, and it should trip if there is the slightest "electricity feeling" in the water. Maybe @castletoniacan comment on the board compatibility. Thx for your input @RDspaguy. @castletonia i really Hope you can help me along ! Quote Link to comment Share on other sites More sharing options...
castletonia Posted August 11, 2021 Report Share Posted August 11, 2021 Assuming the electronics are original, the Caldera part number for the control board is 77089. It looks like the replacement didn’t come with the little daughter circuit board that the original has. I can’t tel by the pictures but it looks like the original might have a different configuration on the bottom right? To me it looks like there are connections directly on top of each other. 1 Quote Link to comment Share on other sites More sharing options...
Merckaert Dimo Posted August 12, 2021 Author Report Share Posted August 12, 2021 22 hours ago, castletonia said: Assuming the electronics are original, the Caldera part number for the control board is 77089. It looks like the replacement didn’t come with the little daughter circuit board that the original has. I can’t tel by the pictures but it looks like the original might have a different configuration on the bottom right? To me it looks like there are connections directly on top of each other. I checked the box and the circuit board I recieved is a 77087. I told them it was for a caldera Aspire and they send me this one. I check further the main board and see on the transistor a bit rust. Could this be the fault? When the hot tub is on, the transistor makes bit noise. ( video attached). Do this look normal? How can I check that the heater board works fine? Measuring voltage white and black cable from the heater? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 13, 2021 Report Share Posted August 13, 2021 Your video is unavailable. There is nothing iron on the board, so it's not rust but may be a problem. If you have voltage to the heater it's fine. It may be fine even if you don't have voltage to the heater, as many things can turn the heater off. Quote Link to comment Share on other sites More sharing options...
Wildlos Posted October 10, 2021 Report Share Posted October 10, 2021 I am having a problem somewhat similar. My "temp" light on the controller keeps blinking and water temp is showing at 50 when its about 75 degrees. I cant get anyone to figure this one out for me? Anyone got suggestions or advice? Quote Link to comment Share on other sites More sharing options...
