2006 Marquis Epic code HOT
Need pics of your circuit board and equipment so we know what you have in there.
Hot, OH, and such are often the result of a flow issue. Remove the filter and see if it clears the error.
Give detailed description of what it does when you turn on the spa. When the HOT comes up is a clue.
When I power up (circuit breaker), it goes through power up cycle (240v, etc) then displays HOT. None of the control buttons work/respond.
