clk Posted November 28, 2005 Report Share Posted November 28, 2005 i have a 8 month old sundance marin spa which shut down and indicators show Sn1 & Sn3. Does anyone know what might have caused this? i have not had any other problems with the tub and leave the temp set on 100. the sn1 indicates heater disabled or tub deactivated and the sn3 indicates the heater is disabled with the main sensor non-functional. just went to check chemicals and found it this way. unable to reset as it just shuts back off. it was running fine 2 days prior and was not indicating any trouble on the display. have been good at changing filters and checking chemicals. probably over checking if i must admit it. help waiting on them to come and look at it however the owner of the dealership is out with a bad back so the not knowing is killing me. Quote Link to comment Share on other sites More sharing options...
Guzz Posted November 28, 2005 Report Share Posted November 28, 2005 i have a 8 month old sundance marin spa which shut down and indicators show Sn1 & Sn3. Does anyone know what might have caused this? i have not had any other problems with the tub and leave the temp set on 100. the sn1 indicates heater disabled or tub deactivated and the sn3 indicates the heater is disabled with the main sensor non-functional. just went to check chemicals and found it this way. unable to reset as it just shuts back off. it was running fine 2 days prior and was not indicating any trouble on the display. have been good at changing filters and checking chemicals. probably over checking if i must admit it. help waiting on them to come and look at it however the owner of the dealership is out with a bad back so the not knowing is killing me. I guess the owner is the service tech too? Is there no-one else at the dealership that can help you? Quote Link to comment Share on other sites More sharing options...
Brulan1 Posted February 4, 2006 Report Share Posted February 4, 2006 I guess the owner is the service tech too? Is there no-one else at the dealership that can help you? Call other places to get a better idea until your man decides to come back and troubleshoot. Alieves some ambiguity Quote Link to comment Share on other sites More sharing options...
tony Posted February 4, 2006 Report Share Posted February 4, 2006 Call other places to get a better idea until your man decides to come back and troubleshoot. Alieves some ambiguity Hopefully he's got this fixed. It happened over two months ago, lol. Quote Link to comment Share on other sites More sharing options...
Brulan1 Posted February 6, 2006 Report Share Posted February 6, 2006 Hopefully he's got this fixed. It happened over two months ago, lol. Good point. I will calm down now that I am an advanced member. lol Quote Link to comment Share on other sites More sharing options...
