Amy B Posted July 27, 2021 Report Share Posted July 27, 2021 I have an above ground pool which I use chlorine for. I am now getting a hot tub and have heard mixed things about which sanitizer to use. Do I NEED to use chlorine because my pool is chlorine, OR can I use bromine! If it doesn’t matter which one, which do you all recommend? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 27, 2021 Report Share Posted July 27, 2021 Does your spa have ozone, uv, or any inline dispenser (frog@ease, smartchlor) or a salt cell? What brand and year? Quote Link to comment Share on other sites More sharing options...
waterbear Posted September 1, 2021 Report Share Posted September 1, 2021 On 7/27/2021 at 4:07 PM, Amy B said: Do I NEED to use chlorine because my pool is chlorine, OR can I use bromine! You can use bromine in the spa and chlorine in the pool. Many would recommend rinsing off before going from the spa into the pool but you can go from the pool into the spa with no problem. On 7/27/2021 at 4:07 PM, Amy B said: which do you all recommend? I prefer bromine in the spa because it is a bit easier and more forgiving. There is a pinned post on setting up and using 3 step bromine. However, many people are quite happy with a chlorine spa, even though it is a bit more work, IMHO. Quote Link to comment Share on other sites More sharing options...
