Jacuzzi J-LX replace PowerPro RX Jet with 6541-288 (recommended replacement)
noah
I have some broken spa jets (20093-001), and I've ordered the replacement 6541-288. I was told the inserts were compatible. Is that true?
If that isn't true, which it seems not to be considering what I've managed to pull apart so far. Do I now have to take the spa wall off and replace the whole mechanism (connecting the spa pipes and such)?
Thanks for any help,
Noah
What's left of the old one after I managed to remove the top piece, and after are pics of the new insert.
IMG_4951.thumb.jpeg.d2ed5a0916245e18e76bc2c3f41c0d61.jpegimage.thumb.jpeg.dd3c8541c03d54639dc65a4e788719c3.jpegimage.thumb.jpeg.33c053e221aac4591060e4c562e72a5c.jpegimage.thumb.jpeg.600796573472f67a9316c26de026414b.jpeg
What year is the spa.
https://www.hottuboutpost.com/jacuzzi-spa-power-pro-rx-jet-with-stainless-steel-escutcheon-20093-001/
Jet has been discontinued by the manufacturer and is no longer available.
See JAC6541-288 which will work in place of this item - depending on your spa model/year.
Jacuzzi® Spa Power Pro RX Jet With Stainless Steel Escutcheon, Includes O-ring, Washer and Nut.
Factory original Jacuzzi® part, no imitations here.
3 1/2 inch jet face. 3.9 inches long.  Used in pre-2013 models.
  • Like 1
I finally spoke to Jacuzzi - from  20093-001, I need to replace the complete jet (back and front) and recommended replacement is 6541-288 with 6541-634 ring. (Note, Jacuzzi had used 6541-566 for a while but that is not what is recommended to replace it with now).
  • Like 1
