Robbo007 Posted July 15, 2021 Report Share Posted July 15, 2021 Hi guys and girls I have a spa pack which I believe is a gecko can someone help and tell me which one I can purchase which will replace this as I don’t think they do this option anymore thanks peeps Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 15, 2021 Report Share Posted July 15, 2021 What is the issue you are having with this pack? 1 Quote Link to comment Share on other sites More sharing options...
Robbo007 Posted July 15, 2021 Author Report Share Posted July 15, 2021 Cp pump doesn’t run at full speed. Flo error comes on, have replaced Sensor and heat element tube and circulation pump. No air locks are pleasant Quote Link to comment Share on other sites More sharing options...
Robbo007 Posted July 15, 2021 Author Report Share Posted July 15, 2021 1 hour ago, CanadianSpaTech said: What is the issue you are having with this pack? Below Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 15, 2021 Report Share Posted July 15, 2021 21 minutes ago, Robbo007 said: Cp pump doesn’t run at full speed Circulation pumps only have 1 speed. Does the spa have a circulation pump or does it run main pump on low for heating and filtering? Post photos of the entire spa pack so we can see the connections and also of the topside control. Remove the filter until the issue is fixed. Remove them from the equation. Just make sure nothing large can go down the hole. Make sure the IN.Flow connection is good. They can be difficult to insert and you have to make sure its a good connection. IN.XE Manual here: https://www.geckodepot.com/fichiers/documentsProduits/GDA/en/Techbook_in_xe_EN.pdf You may have to access the low level programming and make sure it is set up correctly. Where the circulation pump flow comes out in the spa is there flow/pressure? 1 Quote Link to comment Share on other sites More sharing options...
