Jouko Posted June 30, 2021 Report Share Posted June 30, 2021 Hi, I have got a ten years old second hand Watkins Hot Spot Dash pool. It has beer out on use for a year. When trying to put the free pool in operation I found out that water flow can pass the filter trough an opening inside the bottom on filter housing. There is wide free channel between filter input and outouteen. A kInd on separating plate must be missing! Could someone please tel me the missing item. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 30, 2021 Report Share Posted June 30, 2021 This help? Not 100% sure what you have or need. Hot Spot Spa filter assembly. I think you need parts 5 and 7 Quote Link to comment Share on other sites More sharing options...
Jouko Posted June 30, 2021 Author Report Share Posted June 30, 2021 Thank you for your reply. Unfortunately this is not my filter Assebly. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 30, 2021 Report Share Posted June 30, 2021 @Jouko Ok post some photos of what you are looking for. TRY Page 31: https://www.customspacover.com/uploads/documents/files/manuals/hot spot/hot-spot-hot-tub-owners-manual-2010.pdf Quote Link to comment Share on other sites More sharing options...
castletonia Posted June 30, 2021 Report Share Posted June 30, 2021 The Dash was only made from 2010-2012, never seen one personally. 2 Quote Link to comment Share on other sites More sharing options...
Jouko Posted July 1, 2021 Author Report Share Posted July 1, 2021 I googled the problem. At the bottom on Waterway filter housing there should be a springs loaded bypass valve for protecting the filter when high speed. For some reason this item was missing. A spare part is available.. Thank you guys. I am afraid there will still be some more problems to solve before we can bath. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 1, 2021 Report Share Posted July 1, 2021 Now you have to open the face of the pump and remove the broken flapper. The flapper will stay closed when the pump is running in low speed so water is pulled through the filter and will draw open when the pump is put into high speed and will then also draw water through the round pump returns in the foot well to feed the pump more water. 1 Quote Link to comment Share on other sites More sharing options...
