jamace Posted June 28, 2021 Report Share Posted June 28, 2021 I ordered a new board for my maax spa Had to get a update board go it in and all was good but pump 2 and the blower Pump 1 works on both speeds I'll post some pictures All wires and jumpers are the same As the old board The red wire on w15 was on j97 I moved it to j9 And the j83 jumper And I tested the pump 2 and it's working on high and low speed Hope someone can help me I spent the day on the internet before I found this fourm Thanks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 28, 2021 Report Share Posted June 28, 2021 Need to see photo of the schematic on the inside cover. Also the blue box and red box along the bottom of the circuit board they are to fuzzy in the photos to see what's up and what's down. 34 minutes ago, jamace said: all was good but pump 2 and the blower 34 minutes ago, jamace said: And I tested the pump 2 and it's working on high and low speed confusing it work or not? Is the schematic on the inside cover the same as the new board? What has been updated? 1 Quote Link to comment Share on other sites More sharing options...
jamace Posted June 28, 2021 Author Report Share Posted June 28, 2021 Ok thanks I'll take some pictures asap Quote Link to comment Share on other sites More sharing options...
jamace Posted June 28, 2021 Author Report Share Posted June 28, 2021 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 29, 2021 Report Share Posted June 29, 2021 What is the part number on the new board. Do you have a link to where you bought it. If you updated the board the original schematic might be wrong. I would try moving the W15 back to J97 unless there is a reason you moved it. Below clipped from this post: https://www.poolspaforum.com/forum/index.php?/topic/52493-maax-spa-460-series-balboa-54301-04-snb-error/ 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 29, 2021 Report Share Posted June 29, 2021 Dang @CanadianSpaTech, if I didn't know better I'd think you did this for a living or something. 😉⭐ Quote Link to comment Share on other sites More sharing options...
jamace Posted July 1, 2021 Author Report Share Posted July 1, 2021 It took 2 day to get the schematic I put W15 back to J97 and switch a2 on and switch b1 and b3 on all is good I wish I had got schematic with it EL2000 55065-04_97_A.pdf 2 Quote Link to comment Share on other sites More sharing options...
